Help removing manual lever on 4R100 transmission on 2004 F250
I have a 2004 F250 and I am trying to remove the manual lever on a 4R100 Transmission, but I am not able to figure out how to remove it. There seems to be a 'pin' that is keeping it in place, if that is the case, how do I remove the pin?
The yellow circle is the manual lever (unless it is called something else ) the red circle is the 'pin' that needs to come out. Thanks
