F-250 / Super Duty / Diesel
Hard starting 7.3
Old Aug 21, 2001 | 10:35 AM
triplespool's Avatar
Question Hard starting 7.3
This is the first time i have wrote to this web page. I have a f-350 crewcab 4x4 off road diesel (turbo) not a powerstoke. The truck is a 1994 model with 240000 miles on it. The injecters where changed about 45000 miles ago and new glow plugs installed. The trucks starts and blows white smoke bad and has a bad miss in it., after the truck warms up it is fine no problems. The injecter pump has never been touched. If anyone has any info i could use it. Also i have heard that the 1994 models have a knocking noise in the lower end, one person said it was wrist pin slap, has anyone else heard of that year have alot of problems with this. Thanks for any help.......
Old Aug 21, 2001 | 12:56 PM
Theologian's Avatar
Diesel engines that blow white smoke on start up often have a problem with injector leaks air in fuel lines, and fuel starvation. That it goes away when the engine warms up suggests that could be the problem. I have not had that problem with my Powerstroked F450 yet, (150K) ... but I have had semi's with that problem. If ignored the problem will get very much worse. Either do it yourself or have someone else check the injectors, and intake system.
Wm
Old Aug 21, 2001 | 07:22 PM
Tina's Avatar
I just want to welcome both Theologian and Triplespool to the Ford board. Two new diesel people in one day, cool
wish I knew something about the older powerstroke to help but the best I can do is to point you to another board that deals in nothing but diesels www.ford-diesel.com When you find out what your problem is, post back here.
Old Aug 21, 2001 | 10:34 PM
Smile THANKS TINA
HELLO TINA.....Thanks for the warm welcome....I will post the problem or problems when i figure them out...I can not say one bad thing about my truck, i have worked it hard and it has never let me down. Take care for now ..Thanks again..
Old Aug 25, 2001 | 03:04 AM
ecm747x's Avatar
Hey Screw Stick!,
Hum, let me get this straight, it blows a lot of smoke when you start it and then misses?....Wow sounds to me like you are in a L-1011 p.o.s...Ha HA.........YOu sir are an idiot..LOL 4 holer all the way baby! At least I know how the E.P.R sytem works and you still cant figure it out....If you like the l-1011 I would have thought you to be a Chebby driver....At least you have one brain cell working...LOL And I will have to be carrying your rear end again this hunting season and since we are on the same shift your a$$ at wotk too? ...HELLO! Bye bye and see you Sunday at 8......
