Bearing Carrier Shim: Can't get rid of Vibration.
I have vibration in the drive line that is occurring when I take off up until 20 mph. I've started with 1 (1/4") shim and gone up to 9 shims installed. At 8 shims the drive shafts are pretty even with one another. That's where I have it set now with the least vibration, but can't completely get rid of it. Anyone have any other senerios? Maybe different size shims?
I have 6" of lift in the rear. Rule of thumb is generally (1) 1/4" shim for every 1" of lift. That should put me at 6 shims, but it's not working.
Another thing is the OUO blocks have 3 different pin holes to align the differential. I used the middle hole. Is it possible the rear end is to far up or to far back?
I have tapered blocks so the pinion angle is pretty good. I'm going to mess with it this weekend and get some pics of all the angles.
