F-250 / Super Duty / Diesel
glow plugs...??
Old Dec 1, 2010 | 07:44 PM
07 FX4's Avatar
glow plugs...??
I own a 01 f350 7.3, and this morning it took me 40 minutes to get it started!!!!!!! it dropped to about 20 degrees last night and it was plugged in from about 6 pm last night till 6am this morning. my question why did it take so long to get it started it has never taken me this long...could it be bad plugs or a relay or something??? im tryin to stay away from ether but looks like I jus might have to use it.
thanks
Old Dec 1, 2010 | 08:27 PM
adrianspeeder's Avatar
Only problem with the glow plugs on a PSD is you gotta pull the valve covers to get 'em. Takes about 2-3 hours.
I would first start with checking for power on the relay itself. Do you have a multimeter?
Adrianspeeder
Old Dec 1, 2010 | 08:34 PM
07 FX4's Avatar
yes I do...I will check it ASAP
Old Dec 2, 2010 | 12:40 PM
Zaairman's Avatar
Check the relay, but if its taking that long with it plugged in, I'm thinking you have other problems.
Old Dec 2, 2010 | 08:29 PM
CTC B4Z's Avatar
probably a gelling of fuel issue or a ICP system leak... If a good condition 7.3 is plugged in, it should start w/o cycling the plugs
Old Dec 8, 2010 | 09:54 PM
07 FX4's Avatar
update: bad relay!!
