F-250 / Super Duty / Diesel
6.0 troubles
Old Oct 22, 2010 | 09:12 PM
f150fella08's Avatar
6.0 troubles
a friend of mine has a 2006 (i believe) f250 with a bullydog programmer he only runs on tow mode, he says under 1500 RPM it shakes really bad, kinda like when an IDM goes out. and he says he gets a DTC for number 7 missfire. he has had the EGR replaced,
anyways. someone told him if he changed that side injectors/rail it should solve the problem
and i have already informed him about the head studs/EGR/oil cooler and all that jazz
Old Oct 22, 2010 | 09:48 PM
see if CTC will show up, he works on these all the time
Old Oct 23, 2010 | 11:14 PM
taterthedog's Avatar
I would only change the injector that was missing. No sense changing one full bank.
Old Oct 24, 2010 | 12:48 AM
Zaairman's Avatar
I'd bet that his IDM is going out. It'll probably show codes for all injectors soon. Just to be sure, swap the #7 injector with another one on the truck and see if the code moves with the injector.
Old Oct 24, 2010 | 09:53 PM
ok makes sense. we'll try that
