What size tires/rims can i get away with
Sup folks, i have a '03 f250 SCAB. Thats the extent of the fancys. I want to put new rims and tires on it. Can i get away with 18" rims with 285s? rubbing? you guys seem to know everything. If anyone has any pics of trucks that have this done i would love to see what im batting with.
You need to worry more about the overall diameter of the tire more than just the width. The 285 in the tire size refers to the width in mm.
A 285/65/18 is ~33" tall and should fit fine as long as the offset isn't anything wild.
A 285/65/20 is ~35" tall and will rub without some sort of lift.
I know a fella running a 305/70/18 that is 35" tall on his 07 350 - it doesn't rub (but it's the 05+ coil front set-up)..so one should consider both diameter and width together.
check tire specs - example:
http://www.****cepek.com/tires.php?item=RadialFCII
http://toyotires.com/tire/pattern/open-country-at
I am actually thinking a 285/75/18 will be perfect for me
You can run a 305/50/20 with no issues. I currently have 285/75/16s on my truck and with my Eagle wheels, they rub the inner fender when I turn all the way to the left, but only a little. When these tires were on the stock wheels, I had no issues with rubbing.
Keep in mind if you go with aftermarket rims they will probably be wider and may rub.
