F-250 / Super Duty / Diesel
sound question
Old Dec 18, 2009 | 09:28 PM
ZeroDormancy's Avatar
sound question
so my diesel sounds like its running rough as hell for the first about 30 seconds-1 minute its running. is that normal for the cold weather or what?
Old Dec 19, 2009 | 12:42 AM
FL4X4's Avatar
Which diesel do you own? and it could be normal depending on how cold it is...
Old Dec 19, 2009 | 01:26 AM
freekyFX4's Avatar
diesel engines don't like the cold. remember, diesel engines don't have spark plugs, so they use heat and pressure to cause combustion. when an engine is cold, it is harder for the engine to fire. the reason for glow plugs is to heat up the combustion chanber prior to starting the engine. this is also the reason that diesel engines have block heaters. if i keep mine in my garage overnight, it runs smooth as silk from the get go. if it stays parked outside in the cold overnight, it takes a mile or two for things to smooth out. this is normal for a diesel.
Old Dec 19, 2009 | 03:01 AM
GreenBuck50's Avatar
I think he bought a used 6.0 a month ago or so... this is his first winter.
Old Dec 19, 2009 | 05:10 PM
yep, 6.0 first winter first diesel. i plug it in and let the plugs warm for a bit. i figuerd it was normal but i just wanted to make sure cause it sounds rougher than good lol. thanks all
