F-250 / Super Duty / Diesel
Misses while Idleing
Old Sep 15, 2009 | 07:48 PM
1966Ford's Avatar
I have a 2005 Ford f250 has a few problems all of a sudden. Starting today the truck will idle barely. Once you put it in gear it will go like usual. Put it in park or neutral and rev it up it will only go to 3000 rpm, when you let off it will die most of the time. Any Ideas?
Old Sep 16, 2009 | 07:56 AM
dsq3973's Avatar
What engine does your truck have and when was the last time you changed the fuel filter or filters?
Old Sep 17, 2009 | 12:23 AM
1966Ford's Avatar
It has the 6.8 V10. I changed the fuel filter right after it started doing it. I only know of the one filter. I have had work trucks act like this when they over heat. Like they are running on 6 cylenders, but when I put it in gear it goes like usual. There isn't any check engine lights on at all.
Old Sep 17, 2009 | 02:39 PM
dsq3973's Avatar
When was the last full tune up done to the truck? I would start looking for faulty plugs, plug wires, or even bad coil packs.
Old Sep 17, 2009 | 05:05 PM
04f150xlt_fab6's Avatar
Have you checked your mass air flow sensor Mine was doing that also i have 04 4.6l but some what off the same thing try diconnect negative on battery clean mass air flow sensor with cleaner from autozone connect battery and turn key on let guage light clear then start let idle for a few min then drive it see if that helps.
Old Sep 17, 2009 | 06:50 PM
1966Ford's Avatar
I havn't done a tune up on it. The truck only has 42000 miles on it. I thought everything should be good until 100000 miles.
Old Sep 18, 2009 | 09:42 AM
dsq3973's Avatar
That a good point I would also check the MAF and see if its dirty and clean it if it is.
Old Sep 18, 2009 | 07:22 PM
Pagnew's Avatar
Did you have a computer check on it - maybe a code will come up that can guide ya in the right direction
Old Sep 27, 2009 | 11:36 PM
1966Ford's Avatar
I cleaned the mass air meter and the truck still acts the same. When in neutral it will only rev to 3000 rpm. It will only idle at 500 rpm. Sometimes when I come to a stop it will die. I suppose I will have to have it looked at. There is no check engine light that comes on.
Old Oct 14, 2009 | 09:13 AM
1966Ford's Avatar
I took the truck in and found the po506 trouble code. I guess ford has a service bulliten out saying the pcm needs reprogrammed and if that doesn't work more than likely I need a new throtle body. Any body else have this problem?
