New exhaust w/ pics
New exhaust w/ pics
OK so it's not really a "new" exhaust...mostly just a new tip. Unlike some people...ehem...JesseRohr....ehem......
I can't afford buying an entirely new exhaust system right now, so for the time being I cut the muffler off and ran 4" straight pipe from the turbo back w/ no cat into a 5" 45 degree elbow that dumps right after the cab. I got the tip from xtremediesel.com -thx JesseTo be honest, I doubt I'll ever get an exhaust system now because it sounds GREAT. Tell me what you think.
It's a little difficult to see, so I may end up having the pipe adjusted down more, or run some more pipe so it dumps after the axle, not sure yet.
That tip looks strangely familiar, I like it. And i agree a straight pipe is a straight pipe, MBRP makes awesome stuff but for $1200 I'll take my custom $300 setup which sounds/performs identical.
here's kind of an older pic
wouldn't be hard to set yours up the same way
Thx...Good eye Jesse. I haven't used the goose neck yet, it's actually a Pop-Up retractable ball. Our toy hauler was just a standard type receiver, but I'd like to get a 5th wheel in the future. Here is a pic when my truck was still stock.
Sure it costs about the same as a complete 5th wheel hitch but you don't have to worry about carrying the extra weight or taking the hitch in & out of your bed. Plus it's adjustable for different bed heights so you can level out the trailer.
The good thing about already having a GN is you can use a kingpin adapter if you get a 5th wheel trailer - depending on the weight. The kingpin adapter will support 24,000 lbs. gross trailer weight & 6,000 lbs. gross tongue weight.
Its actually straight pipe from the turbo all the way to the tip. The previous owner had an aftermarket muffler on there w/ no cat but I didn't like the muffler cause it was too quite plus I dented it pretty good offroading one day before it was lifted, so I just cut the muffler off and added this tip.
How loud is it cruising and under acceleration with the trailer on behind the truck. If I do this and its to loud in the cab I will never get my wife to do long trips with the fifth wheel.
that looks good but I like dual 4"s 90* behind the rear tires, nothing like fogging up a hill leaving twin clouds that melt into one
them yeller superduties are starting to grow on me
and its loud....something you don't hear w/ a stock exhaust and many aftermarket ones. You will hear the growl in the cab but at crusing speed it isn't too bad, pulling a trailer it gets a little louder but hey it's a truck, not a Cadillac
I know what you mean though about the little lady, mines the same way. I'm probably going to dynamat the whole truck soon which will quite it down some & probably going to run more pipe so it dumps after the axle, maybe even duals like tarajerame suggested if my exhaust shop gives me a good price. Both options will reduce noise inside the cab.
I am going to do this because I am really the only one that rides in my truck 90% of the time and I will keep the stock exhaust if I dont like it. Plus I want to annoy my neighbor when I crank it up in the winter and let it run on high idle to warm it up.
