F-250 / Super Duty / Diesel
Shaking
Old Jul 20, 2009 | 07:48 AM
Green_Machine's Avatar
Shaking
Hey guys. I just bought a 03 f250 crew cab fx4. It has the 100th cenntenial package on it. It has the 6.0L. ive heard alot of bad things about this motor. Are there any good things about it? Mine is running great except one thing.
When your driving and get to 50 its fine. but when you accelerate anytime between 50 and 60 it shakes. after 60 it stops. I cant figure out what it is. Any takers???
Thanks. Ill get pics up soon.
Old Jul 20, 2009 | 10:36 AM
dsq3973's Avatar
Sounds like a tire that it out of balance.
Old Jul 20, 2009 | 10:49 AM
Originally Posted by dsq3973
sounds like a tire that it out of balance.
wouldnt it do it all the time if that were the case???
Old Jul 20, 2009 | 11:17 AM
dsq3973's Avatar
No not always. I have driven trucks that were like this and had the problem solved by rebalancing and rotating the tires.
Old Jul 20, 2009 | 11:25 AM
Ive heard so much.....from the tires, to drive shaft, injectors, front end, you name it.
Old Jul 20, 2009 | 11:28 AM
dsq3973's Avatar
If it was the injectors or drive shaft it would happen through out the entire RPM range. Start with the simple things to eliminate and work your way up the chain until you solve the problem.
Old Jul 20, 2009 | 11:37 AM
Pagnew's Avatar
dsq3973 is heading in the right direction if your feeling it through the whole truck. I have had alot of experince with unbalanced tires in many vehicles and it always started vibrating in the 50-60 range....at speeds under and over that range there was little in no vibration That is your less-expensive route to check first.
Old Jul 20, 2009 | 12:20 PM
fx4 for life 79's Avatar
i agree
Old Jul 20, 2009 | 12:24 PM
well seeing how nothing good is every said about the 6.0L is there any upgrades that I should avoid doing? I am getting ready to put a edge then an open the exhaust to a 4'' straight pipe to a 5'' tip.
let me know guys, and thanks to responses!!
Old Jul 20, 2009 | 02:04 PM
Zaairman's Avatar
Rotate and balance, then go from there. My truck has a bit of a shimmy from the tires that are on the front right now. I know that when I rotate them it will go away.
Any good things about the 6.0? Well, after you save for headstuds and EGR delete, it will be a good little motor.
Old Jul 20, 2009 | 02:14 PM
Originally Posted by zaairman
rotate and balance, then go from there. My truck has a bit of a shimmy from the tires that are on the front right now. I know that when i rotate them it will go away.
Any good things about the 6.0? Well, after you save for headstuds and egr delete, it will be a good little motor.
how much am i looking at for that?
Old Jul 20, 2009 | 02:20 PM
dsq3973's Avatar
ARP Head studs are about 550 and the EGR delete kit is about 400 to 500 depending who you buy it from. And to have the head gaskets done is about 1300 to 1500 because they have to take the cab off to do them.
Old Jul 21, 2009 | 06:33 AM
that sounds like fun. I just found a warranty company that will cover the entire truck for 60 month or 100k for 76 dollars a month. So i am going to get that just be on the safe side with this truck. I am hoping with 120k that all or most of the bad things have been fixed. Ive been told its a good chance that most of it has.
