goosneck towing advice needed
I currently have a 2006 f-250 diesel ext cab long bed, I absolutely love it and can't afford a second...
i need to pull a 4-horse goosneck trailer GVWR is about 6900lbs and length of trailers range from 28-32 feet.
Is it possible (and safe) for me to pull this with my truck or do I definitely need a dually?
If def dually what trailer length would my truck be safe hauling?
Not sure what your pin weight is but I pull a 31' 5vr that comes in at about 11980#'s loaded for a week. My pin weight is in the 2300# range and I am safe on all axle rating numbers, and total combined gross weights. My 05 is rated at 10,000 GVWR, but I did add a set of super springs.
I have pulled and stopped this set up thru mountains with no problems so you should be ok.
