F-250 / Super Duty / Diesel
Diesel Leak
Old Jan 22, 2009 | 08:04 AM
4.2trimble's Avatar
Diesel Leak
1999 F250 7.3L Powerstroke
I went out this morning cranked up the truck to get the heat going. I walked back inside for a total of 5-6 minutes MAX. When i came back there was a BIG puddle of diesel under the engine. It was kinda closer to the passanger side but pretty close to direct cent under the motor.
The leak was still pouring out, and didnt stop till i turned the truck off.
what do i need to check.
Old Jan 22, 2009 | 08:31 AM
4.2trimble's Avatar
bump
Old Jan 22, 2009 | 09:13 AM
wdhurley's Avatar
I had the same issue on my 99 f-250. the water separator has little o-rings in it that don't like this new kinda of diesel. The fuel eats away the o-rings and voila, bad leak... it can also make your truck run like crap from losing prime. really quick google search popped up with this http://www.thedieselstop.com/forums/...-valve-209901/
really easy to fix.. three screws, pop out the old o-rings, pop the new ones in.
Old Jan 22, 2009 | 01:13 PM
Zaairman's Avatar
Fuel bowl drain 0 rings. $2 in parts, 30 mins if that to do it yourself. Screws are a pain in the *** to get at though.
Old Jan 22, 2009 | 01:45 PM
4.2trimble's Avatar
alright guys, i think this is the problem. i went out and took the little plastic cover that says 7.3L on it and the water separator was under there. It wouldnt leak imediately after turning it on but after about 2-3 minutes it would start pouring out.
Old Jan 22, 2009 | 02:00 PM
Okieboy's Avatar
Yea, Zaairman is right. Easy fix, I replaced my @ 50+ bucks before I knew that you could rebuild it. I heard that if you need parts for the 7.3l go to international, they don't have the mark up on price. Good luck
Old Jan 22, 2009 | 02:10 PM
4.2trimble's Avatar
man i cant seem to track this O-ring down. Discount doesnt sell them they only have the whole separator. and its an order only part
I cant find the parts at autozone either. I was hoping to get this fixed today. Is that just not gonna happen?
Old Jan 22, 2009 | 02:12 PM
4.2trimble's Avatar
would this be the thing im looking for?
http://www.autozone.com/R,255198/sto...ductDetail.htm
or this
http://www.autozone.com/R,2831504/st...ductDetail.htm
Old Jan 22, 2009 | 02:13 PM
Okieboy's Avatar
Yea I feel your pain! Took me 2 days to find. Is it coming out of the yellow handled bleeder valve?
Old Jan 22, 2009 | 02:15 PM
Okieboy's Avatar
No take off the separator and dis-assimble then go to autozone and have them pull out their "O" ring sizing Kit! You may end up going to ford or international
Old Jan 22, 2009 | 02:19 PM
Okieboy's Avatar
You may want to purchase some di-electric silicone grease for spark plugs. That will help is seat and seal better!
4.2trimble's Avatar
that fricken sucks.
My truck is down untill the Suspension if finished. Probably not till mid febuary and this is my transportaion till then.
ok guys ill do that.
Old Jan 22, 2009 | 05:16 PM
Zaairman's Avatar
Nobody will have O rings that will work, they will be the right diameter but not thick enough.
http://cgi.ebay.com/ebaymotors/Ford-...Q5fAccessories
Old Jan 22, 2009 | 07:51 PM
powerstroke73's Avatar
As Zaairman pointed out they are not a standard size. You may be able to match an ORB oring to the OD, but it won't match the ID. They also need to be rated for diesel fuel and high temps. Not all o-rings meet this spec. Viton is the most common compound that is used for this application. If you search ebay for viton orings you'll get a ton of auctions selling the 2 you need.
Zaairman, it really took you 30min to change them out? I think it took me 5 to do it on one of our service trucks along side the road. Stop for a beer or 6 in there?
Old Jan 22, 2009 | 08:27 PM
Zaairman's Avatar
It was 20* outside, in a parking lot, and my bumper was icy.
