F-250 / Super Duty / Diesel
What's the best CAI for a 2006 5.4L?
Old Nov 30, 2008 | 11:44 PM
black_z's Avatar
My father has an 06 F250 with the 5.4L and I'd like to get him a good CAI. Possibly one that'll gain him a couple MPG!
Old Dec 1, 2008 | 06:23 PM
black_z's Avatar
Did I post this in the wrong section?
Old Dec 1, 2008 | 07:34 PM
Zaairman's Avatar
No... It's just that nobody really has an F-250 with the 5.4.
Old Dec 1, 2008 | 07:50 PM
black_z's Avatar
I understand that. Tried to talk him out of it.
Old Dec 4, 2008 | 02:44 PM
Ray21's Avatar
If he wants more power and possibly more mpg then I think a programmer would be a better option than a CAI.
Old Dec 4, 2008 | 03:03 PM
Yep, a programmer will give you much more, plus, a CAI really can't help a lot unless you have a tuner that takes advantage of the extra air available, plus, if he doen't have an exhust, you need to be able to expell the extra air. Basically, to take advantage of a CAI, you need a custom tune and an exhaust, but you can get great results from a tune by itself.
Old Dec 4, 2008 | 05:04 PM
black_z's Avatar
Cool!
What all types of programmers are there for the 5.4?
Old Dec 10, 2008 | 12:45 PM
Ray21's Avatar
I would go with a custom tuned SCT or Superchips
Old Dec 18, 2008 | 12:27 AM
black_z's Avatar
Thanks for the info guys!
What is another good forum for the F250s?
Old Dec 18, 2008 | 07:39 PM
Zaairman's Avatar
For a gas F-250? I'd say stick with this one really. Not a whole lot of motor differences between the 5.4 F-150 and 5.4 F-250.
Old Dec 22, 2008 | 10:03 AM
kingcrete's Avatar
Cool!
Just had my ECU tuned by http://www.reinhartautomotive.com/ using a SCP x calibuer Cost me $175. The tech turned off my o2 sensors, eliminated my top speed, changed my shift points for a firmer shift at full throttle, adjusted the timing, added some spark (which i can only run 93 octane now) but i only drive the truck on the weekends and if i want he can change it back in 5 minutes.
I would call around to see if anyone would be willing to tune your ECU. The shop that did mine specialize in mercury marauders and 4.6 and 5.4 engines, And they do alot of tuning for The Florida Highway Patrol.
Old Dec 22, 2008 | 10:11 AM
Get a tuner with custom tunes. Your best choices for experience and knowledge is the Xcal3 tuned by VMP or Troyer Performance, or the Gryphon tuned by Power Hungry Performance. You can have up to 3 tunes with varing octane and purposes, such as performance or towing. With a tuner, you will be able to switch between tunes in about 1 minute.
Old Dec 23, 2008 | 05:37 AM
openclasspro#11's Avatar
i assumed he turned off the 2nd set of 02's only ?
Old Dec 23, 2008 | 04:37 PM
kingcrete's Avatar
Yea front o2's are still on of course the front o2's control the air/fuel mixture. While the rear o2's measure the catalyst. turned the o2 switches off and the rear o2 downstream sensors off as well
