Cold Start
Cold Start
We have a F350 Lariat 7.3L diesel, 2003, hates the cold, well cool even, won't start without block heater even at about 38 f. Is this normal? glow plugs? relay? Any info would be appreciated. Also biggest tires that would fit this truck stock.
Change all 8 glow plugs and the relay. If one goes bad it tries to drag down the remaining 7 and the relay. If its already starting that hard then this has already happened. Its not really a hard job as much as its a pita. Just pray the plugs don't fall apart when pulling them out and try and fall into the cylinders.
Largest tire you can fit on the stock rim is a 285/75/16. You can fit a 305/70/16 without a lift, but you need to go to an 8" rim (stock is 7" wide). The 305 is the same height as the 285, just wider (33x12.5).
Find your local Navistar/International truck dealer. Thats where Ford gets its PSD parts from since Navistar builds the engine. By the time you buy it from Ford they've put their markup on top of the markup Navistar charges to them.
thanks alot, here is a site with a guys essay about changing glow plugs without breaking them or how to remove pieces if you do. Some interesting pics.....http://www.members.shaw.ca/k2pilot/G...20article.html
Sure that works for the 6.9L (what the article was written about) or the 7.3L IDI, but the heads on a PSD are different. You're talking direct injection vs indirect. Though some of the tips in there could probably be adapted.
Thanks a lot for posting this essay help. This is a great resource for us.
^^^^^^^ Spammer. Post has been reported.
DO NOT CLICK THE LINK!!!!!!!
