F-250 / Super Duty / Diesel
Quick questions about diesel engines...
Old Jun 4, 2007 | 12:27 AM
Stevenn1's Avatar
Originally Posted by Zaairman
Yep. You're wrong.
Automotive starting/charging systems are either 6- or 12-volt. 6-volt are the very old cars. A diesel is still a 12-volt system. So you can still use it to jump start a gasser. If the batteries were wired-up in a series, it would then be a 24-volt system (like when adding 2 1.5-volt 'D' batteries to a flashlight makes it a 3-volt). It is always a good idea to replace all batteries even when just 1 fails.
Old Jun 4, 2007 | 10:38 AM
stevlin's Avatar
From my experience when you replace one battery the other one usually goes shortly after. You make your own decision on that.
Batteries - parellel just the same as ag tractors and semi's.
Stevlin
