Transmission Problems!!! Any Ideas?
i have a 2005 f-250 super duty and i had a problem with the trans yesterday the problem is the message center said to check trans temp and the needle was pegged out on the cold side and the tow/haul light was flashing also when you put the trans in gear and hit the gas petal it would not do anything (truck would not go or engine would not race up) then after holding the petal down for about 5 sec's it would finally work. anyone have any ideas or suggestion on this problem?
