4.10 Axle in a V10 4x4?
Originally Posted by Hillhound
Not a big deal but it does cost. I think I've seen guys claim parts/labor around $800 to $1000 depending on what you do.
I'm not trying to sell the 3.73s but have you driven one? It does fine unless you need to tow heavy often (over 10000lbs) or plan on lifting and installing oversize tires/wheels. Plus your engine will be turning a few hundred less rpm at highway speeds. Good luck!
I don't get the 10,200 lb rating, that truck looks like it would pull a house down!
Originally Posted by ride everything
I have driven one, and liked it a lot. The rig I'm pretty set on buying is a 7,500 lb empty toy hauler. With water, bikes, etc, I'm over 9,000 lbs. With the tow rating of 10,200 lbs (4wd), I thought I'd be pushing it.
Gearing means alot. I notice all the new 1/2 tons are coming out with 10000lb trailer ratings and the manufacturers are bragging about them. New Tundra, GM's new 1/2 tons etc. But alot of those models are for 2wd models with 4.10 gears. With a truck like mine, you get a 10500lb rating and still get a 4wd model with only 3.73s plus it has a 1500lbs-2000lbs higher curb weight than any 1/2t ext cab.
Point is, you really have to read the fine print for tow data-especially with Toyota and Nissan entering the market with 1/2 tons and doing anything they can to make their new trucks sound superior. It's gooten really bad the last few years.
And Superduty V10s will pull down a house!
As long as you don't drag it down a road on a trailer you're not gonna hurt anything!
So I got a quote for a gearing change on a 2004 4X4 F-250 V10 with 3.73 gears. 4 wheel parts wants about $1,700 to change the gears, parts and labor, then another $500 for a programmer. Sounds steep to me!
Do I really need a programmer?
You will need a programmer to recalibrate your spedometer after the gear change. You can buy one for less than $500 though, look around and you can find Diablo tuners for under $300.
As for the price of re-gearing, that is not too far fetched, but on the high side. Since they have to do front and rear on a 4X4, it will cost more obviously. I paid $2200 for my 4.56 gears in my F-150, but that was Alaska pricing. I had quotes around $1300-1400 for the same job when I lived in Vegas.
Check out some local driveline and transmission shops and get pricing from them. Just make sure you are going with a quality gear such as Yukon, Ford Racing, Precision etc.
no recalibration needed
You will NOT have to get a programmer to recalibrate your speedometer after the gear change. I went from 3.73 to 4.56 and the speedometer was fine. The Super Duties read the speed off the axle (I believe) and not the gears. So regardless of what gears you put in, the spin on the axle will not change.
Back to checking the ratio, my 99 350 has a tag under a dif cover bolt that is stamped 4.10 and a stamp on the side of the diff that says4/10 handy info if you look for a junk yard swap.
I just checked on parts only for the sd and found that the dana front gears were $500 and the dana rear were $700 so $1700 isn't bad if they are doin' the work. (I priced new, not salvage)
hey ride, mine has 4.10 and so did the other 4 on the lot.
https://www.f150online.com/galleries....cfm?gnum=9511
Any-who, tomorrow's the big day for my new gears. I hope it all works out! Only two days with my new (used) truck and so far I'm stoked!
Nice truck too, that thing's sweet. What did you do with your stock rims?
Originally Posted by BumperB
BTW... I would go with 4.30. I have not heard one complaint from people with those gears in a V10. I was always told to go up one size from the gear you thought you wanted.
As far as the speedo, hard to tell really. I haven't owned the truck long enough to really notice, but if I had to guess, it seems the speedo is reading faster than what I'm doing. Would this be consistent with my gear change - 3.73 to 4.30?
Thanks!
Thanks!
Thanks!
