F-250 / Super Duty / Diesel
F250 Vs F350
Old Jul 26, 2006 | 10:21 AM
Beercat33's Avatar
Question F250 Vs F350
Ok guys, i've been looking at 2004 F250's for a while, and it seems every salesman has a 350 he says will be almost exactly the same. I figure there is a difference in the ride itself because of suspension, but what other issues are there between the two? I'm still steering clear of the 2003's because of the problems they had, but i've never been quite sure what those problems were or if they can easily be repaired.
Thanks for the help.
John...
97 F150 with 150,000 and no real problems.
Old Jul 26, 2006 | 10:50 AM
sandtrax's Avatar
I think the main thing is the gears the 350 would more than likley be lower geared. Also getting a little lower MPG.
Old Jul 26, 2006 | 12:19 PM
adrianspeeder's Avatar
Same axles, same gear choices, same frame, same springs, so whats the diff in the superduty series? Good question. A 350 has 4 inch blocks in the rear instead of 2 inch. A 350 can be optioned with DRW's and a towboss package (2005+). A 350 can cost more to insure so the 250 is available for people that don't need the bigger GWVR number.
Oh, the badges are different too.
Adrianspeeder
Old Aug 13, 2006 | 02:01 AM
FamilyRide's Avatar
I would add, the springs are the same, but spring options are different. And the blocks as adrian said.
Do check your insurance. It can be more expensive although that's stupid considering the difference.
