F-250 / Super Duty / Diesel
05 F250 Tires 315's?
Old Apr 13, 2006 | 12:18 PM
stumble's Avatar
I am a new owner of a 05 F250 and I want to put 315's on it, will this work stock? In my 02 F150 Screw I was able to put 315's but doing a little cutting and cranking up the torsion bars. It sure looks like it should work.
Old Apr 27, 2006 | 03:49 PM
GTRider245's Avatar
Give more info. 315x?R?........need rim size. The 315s on your SCrew may or may not be the same diameter as the ones you want to use for the Super Duty.
Old Apr 27, 2006 | 10:01 PM
stumble's Avatar
I have 16x10 wheels and the tires are 315/75r16. The tires were originally from an H2. When I tried them on the front they would rub considerably. I have done research and I am not sure what to get. The 2 inch leveling kits come with many options, shocks, turnbuckles, whatever. What do I need to do exactly? I am wondering if the leveling kit is going to raise the front so much that the back is to low?
Old Apr 27, 2006 | 11:03 PM
GTRider245's Avatar
A leveling kit on a Superduty runs 35x12.50s just fine. A 315x75R16 works out to a tire with a 34.6 inch diameter and a 12.4 inch width. You should be fine, but what are they options you are talking about?
