V-10 computer code location??
If its anything like a PSD pull the DS kick pannel under the dash. Behind there you'll find the PCM. If you're lucky you'll see a sticker with the code on it, otherwise you'll most likely have to pull the PCM out to see the code. You just need to be careful because they fry themselves real easy.
