Axle Paint problems
Is anyone having paint peeling off their rear axle? I am. It peels off in square inches when I hose of the axle or differential housing. Ford says they paint them to cover rust and do NOT warrant the paint on any frame ,engine , trans etc.,parts underbody.
A good coat of Rust-O-Leum should fix it.
Good Luck.
1999 F-250 XLT Super Duty Crew Cab Long Bed
V-10, Automatic 4R100, 4.30 Limited Slip.
GVW = 6700# Towing Capacity = 13,300#
4 Wheel ABS disks + Reese 15K hitch
Dark Hunter Green. Ford Running Boards.
Grey Rhino-Liner. Captain's Chairs. CD+Tape
Polished Stainless Steel Wheel-well Molding http://members.home.net/jchartier/jnctrk.html
Good Luck.
Mine is the same way. Doesn't bother me any, I'll just paint it myself.
Maybe I'll get an aftermarked cover and install it insted.
'97 F-250 L/D Lariat S/C, 4x4, 5.4, E4OD automatic, 3.73 gears, 4 wh. ABS and 4 wh. disk brakes, gray leather interior,keyless entry w/alarm, outside: white w/gray rocker section, sliding rear window, tow package. Mods- Ford running boards, Ford ventsahdes, Color-matched bug deflector, AVS tail light covers, Tuff Liner bed liner, unknown brand of cat-back exhaust system (previous owner installed).
[This message has been edited by Iggy (edited 09-30-1999).]
