F-250 / Super Duty / Diesel
6.0 owners, please help
Old Dec 9, 2004 | 05:48 PM
MOVEOVER's Avatar
My engine has a rythmic, annoying vibration which is very noticeable between 50 and 60 mph. It feels like a tire is out of balance. The engine is not misfiring, but seems to have something out of balance in the bottom end. I think I read somewhere, that that is what caused oil leaks in some of the early 03s. Of course the dealer says there's nothing wrong with it. I've been in a couple of 7.3L trucks, and never noticed it...
It seems to be speed related. I can't feel it while accelerating, or while revving it in Neutral. If I put it in neutral at 55mph, it goes away.
I drove another one (6L) at the dealership, and it had the same "problem". Could it just be a diesel (or 6.0 diesel) characteristic I need to get used to??????
If it is a problem, do I need to get it fixed before the 36k warranty is up?
Does Ford only do "buy backs" from the original owner? I bought it used from the dealer.
Old Dec 15, 2004 | 02:32 AM
MaXRSmart's Avatar
Does the vibration happens right around 1600-1800 RPM's when there is a bit of a load on the engine? If it does, it is the exhaust and it is nothing to worry about. The turbo will create a harmonic vibration in that RPM range with load on the engine. Ford has a replacement turbo pedestal that helps eliminate most of that vibration/drone.
Old Dec 16, 2004 | 06:12 AM
MOVEOVER's Avatar
Yes, thanks. I'm glad someone finally answered this one. I was pretty concerned about it. Thanks again!!!
Old Dec 19, 2004 | 10:48 PM
FamilyRide's Avatar
First thing Ford does wiht the "drone" issue is to "nutralize" the exhaust. Menaing, loosen it up and let it fall into place relieving any stress.
I got the "drone" only after having my exhaust installed, and only after it shifted a little. I adjusted it and it was gone never to return.
There is a TSB on it.
Old Dec 20, 2004 | 04:59 PM
MOVEOVER's Avatar
Actually, there is an exhaust drone. I don't care much about that though. I'm talking about a vibration that shakes you, just like a tire out of balance or something.
Old Dec 21, 2004 | 10:14 PM
FamilyRide's Avatar
I guess that reply confused me then. You seemed happy to know about the exhaust "drone", but appearently that's not really it, or it is?
Old Dec 22, 2004 | 12:33 PM
MOVEOVER's Avatar
I'd like to believe it's the exhaust. I'm not sure though. The dealership said the truck was OK. Since I'm not a mechanic, I try not to argue with them. I'll be a lot more selective when I buy my next vehicle.
Old Jan 4, 2005 | 08:45 PM
harley2003's Avatar
I had a f150 with a vibration at 50 mph and the dealership re balanced the tries it helped a little. I still complained and they agreeded there was a vibration. Ford canada took the truck for two weeeks and re balanced the tires and a cam tensioner.They said it was okay. NOT . I was in every week with an engine light on and the vibration when I towed the whole truck shook. Fonally the dealer agreed and took the truck back and I ordered a new f250 psd. I will test the truck before signing the papers this time.Oh the also changed the drive shaft and hanger bearing it helped a little.
Old Apr 9, 2006 | 08:40 AM
MOVEOVER's Avatar
Sorry to bring back a really old thread. I searched for "pedestal" and this was the only one.
Now my truck has an unmistakable drone. It started about a week ago. It sure isn't what I was feeling when I started this thread. They're going to change the turbo pedestal. I hope the drive train warranty covers it.
I drove a couple of other 6L 250s at the dealer, and they had the same vibration I was asking about earlier. I guess it's a design quirk I can live with. I hope that's not what causes the oil leaks though.
Old Apr 9, 2006 | 04:11 PM
klassic's Avatar
I don't know about a "design quirk"... my 250 drives like I'm on a cushion of air..
My 04 F150 had a vib at 50 to 60 that went away when it was put in neutral... It was the driveshaft.
Old Apr 9, 2006 | 10:34 PM
Rocweiller's Avatar
I have an 03 and dont have that issue. You have a 100,000 mile warranty with the engine. I would consider that an engine issue.
Old Apr 10, 2006 | 07:14 AM
MOVEOVER's Avatar
The engine warranty covers a lot, but I've found that a lot of items are excluded too.
Old Apr 10, 2006 | 03:12 PM
Nosdog2's Avatar
I would also have the driveshaft looked at. If you have a crew cab, mabe check the carrier bearing.
