F-250 / Super Duty / Diesel
Hose coming off rear axle
Old Aug 10, 1999 | 06:15 PM
4x4's Avatar
4x4
Question Hose coming off rear axle
Just had an add-a-leaf added to my truck today. I like the way it raised the rear a couple of inches, but when I got home I noticed a hose lose and touching the ground. I looked underneath the truck but could not find where this hose(cable) came from. It has a white plastic piece connected to the end of it. The white thing has what appears to be a nipple looking end and some sort of hook. The cable also has one of those metal clips half way down that usually attaches to something else whether it be a hose, etc.. the cable attaches to the rear axle into some sort of connector. The is also another hose connected to this that connects to the brakes I think. I am not sure if I am describing this adequately, but any help or replies would be appreciated.
99 F250SD Black Lariat Crew Cab 4x4, 4inch Procomp lift, 35x15.50 Swampers, 16.5x9.75 Weld Scorpios, Full Billet grill, LIne-X liner, Procomp and Rancho shocks, 40 Series Flowmaster, recalibrated speedo, superchipped,K&N filter
Old Aug 11, 1999 | 08:33 AM
99SDKT's Avatar
Post
I have not looked at my truck yet to confirm this but it sounds like the breather tube for the rear axle. The one end usually connnects to the axle at the same point the rear brake line splitter block connects, and the other end (with valve) should be mounted as high up as possible to keep it away from moisture.
99 F-250SD SC 4x4,5.4l,5spd,4.10ls,K&N,Ram-air,2-Chamber Flowmaster,3' lift,315/75/16 Wild Country All-terrain Radials, Superchip, TPS Set,Dual steering stabilizers, Blue crystal driving lights,Arrow High Top Canopy.dual front shocks,10 disc cd changer, class IV hitch, hood deflector,window vent shades,
Old Aug 11, 1999 | 10:48 AM
4x4's Avatar
4x4
Post
I hope that is what it is. 99SD, if you get a chance to look at your truck please confrim this for me. Also note exactly where it is suppose to be mounted, right now I just clipped it to the small metal bar that runs close to the rear differential. Mounted parallel I guess. Thanks for your time and help
4x4
Old Aug 11, 1999 | 11:11 AM
spaceace's Avatar
Exclamation
It is the differential breather tube. It comes through the brake line block mounted on the drivers side axle. It has what looks to be a white y in the end. The clip is metal and mounts on the inside of the frame, on the top, directly above the bump stop.
1999 F250 SD CC, LWB, 5.4L, Auto, 4x4, Power TT mirrors w/ marker lights installed, White, Full Tint, PendaPro SR,
Flowmaster Delta 40 series, open airbox w/ K&N filtercharger.
Old Aug 11, 1999 | 11:16 AM
spaceace's Avatar
Question
4x4,
If you get a pic of your rig with the ProComp lift on, could you send it to me?
spaceace@worldlynx.net
Old Aug 11, 1999 | 01:17 PM
4x4's Avatar
4x4
Post
Thanks for the confirmation spaceace. Will be glad to send you a picture, if I can figure out how to scan it and e-mail it. If all else fails e-mail me your address and I'll mail you some.
Old Aug 11, 1999 | 01:45 PM
spaceace's Avatar
Post
4x4,
I need a reply address. I wanted to respond. I like the second set of pics.
Old Aug 11, 1999 | 02:10 PM
ccla's Avatar
Post
I wanna see
ccla@eatel.net
98 F150 2WD,Bright Red, Regular Cab, 4.2, 3.55, Superchip, 3 Inch Bullseye Lift Spindles, Manik Grill Guard,Nerf Bars, Vent Visors, Fog lights, Kc Lights, Alpine CD Player, 2 Kenwood Amps, Tinted Windows. And Coming Soon: 3 Inch Body Lift Kit, 16x8 American Racing Baja Wheels Wrapped With 33's
And Sooner Or Later A Superchips Decal Or Two
