F-250 / Super Duty / Diesel
Tire size on 02 F250 4X4 help
Old Apr 7, 2004 | 02:11 AM
BlackyF-250's Avatar
I Just got a 02 F-250 Superduty 4X4 Deasil,with a 2in leveing lit and i had 2 questions, first
what is the bigest size tire i can put on the stock wheel with my with that leveing lift?
secound will this aftermarket wheel and tire combo fit under the trunk with just the leveing left?
(tire-33/12.50R16.5-rim-16.5x9.75 8 lug)
thanks a hole,hole bunch for the help.
Jake
Old Apr 7, 2004 | 08:21 AM
runnert's Avatar
Do you want to stay within the legal tire specs? then I think the biggest tire you can put on stock is a 265/75/16. Our trucks recommend using the "E" rated tires since we can tow a lot. But I have a friend who has put on 305/75/16 D rate without a lift or leveling kit. He tows a 5000lb gooseneck without any problems. Now what I have done is put on the 8" rims and put on the BFG's 295/75/16 which has the same load rating as the "E" 265's. I bought the wider rims just for the recommended tire size. I tow a total of 15000lbs loaded gooseneck horse trailer. So I would recommend getting the wider rim (got mine off ebay for $375), but you don't have to if you are not towing a lot of weight.
runnert
Old Apr 8, 2004 | 03:54 PM
JDMnAR's Avatar
Personally, I wouldn't go bigger than a 285/75/16 on the stock rim. Anything larger than that and you are well outside of specs for rim width according to most tire manufacturers.
Heighth wise, the 33's will fit with the levelling kit, but someone else will need to chime in regarding the potential for rubbing with that width.
Old Apr 11, 2004 | 01:29 PM
roggi iceland's Avatar
with new fender you could go with 38" tires
Old Apr 11, 2004 | 02:02 PM
wandell's Avatar
I have a friend running 315/75-16's (35x12.50) on 16x10's with just a 2 inch Jack It leveling kit. It looks great.
Old Apr 17, 2004 | 05:09 PM
jlayne's Avatar
Talking Me tires
I have 305/70/16 on stock rims no lift... tires never get close even with trailer, crossing ditches, anywhere.... oh its a F250 PSD 4x4
