F-250 / Super Duty / Diesel
engine dead ,next time i´m dead
Old Mar 25, 2004 | 04:09 PM
roggi iceland's Avatar
had my f250 diesel for a month now and had a good time one think bothers me,, 2 times the engine has just died going from idle and in both case taking a turn in to a lane,, not the nicest thing to happend having a cars nearly crashing my side,, both time the engine was hot. but easely starts up again,,
anybody know anythink,,,,,
grettings....
Old Mar 26, 2004 | 08:36 AM
runnert's Avatar
My first thought is the CPS, but when that goes out, you cannot start again until you replace it. Check over at the dieselstop.com and do a search or ask your question.
Runnert
Old Mar 27, 2004 | 12:35 PM
FamilyRide's Avatar
I'd get it checked by the dealer, but also, as said, try TDS www.thedieselstop.com and look for threads about a wiring harness problem.
I'm assuming since you said you've only had it a month, it's a new one.
Old Apr 11, 2004 | 12:40 PM
how long time does your truck take to start up, it takes mine over a sec or two,. just start to wondering , those toyotas arond are just a tenth of a sec..
I have the 6l.diesel
Old Apr 11, 2004 | 05:52 PM
thanks. guys.. just post at TDS ....
the truck has gone worse. and now only runs few sec idle here on the parkinglot....barly made it home...
Old Apr 17, 2004 | 01:52 PM
nice to get all the replies..
Update on my problem..
Dealer finally had time to connect to cpu and it gave 12fail codes
out of 13 possible. 12 out of 13 nice...
they asked me if they could continiue to look for the cause,,,,
Monday i will hear from them..
Old Apr 18, 2004 | 07:00 PM
now i have 5replies out of 6 that is a record jibí
Old Apr 23, 2004 | 05:24 PM
Update... the FICM injector drive module is dead got a buy a new one... 2000$ viva Ford..
Old May 14, 2004 | 02:55 PM
jlayne's Avatar
i just put a IDM on my 2000 7.3 and it was around 600 from the dealer and labor is very minimal... if you did it yourself it is very easy... i think you might want to get a second price, sounds like the dealer is doing you. good luck sometimes the dealer can be hard to work with. also try replacing the injector harness under the valve covers it is around $150 and when it goes out it will make the truck give off IDM codes (been there broke that) that might be a cheaper way to start off.
Old May 23, 2004 | 12:00 PM
gearmanx17's Avatar
For these electronic gizmos on 6.0 and 7.3L engines; if you can verify the part with the problem and view it, it will probably have a Navistar part number. Call local Navistar dealer and get the price and availability for the part you need. Just for reference: 6.0L is a VT365 Navistar and 7.3L is the T444E Navistar engine model designation.
Waterpumps, pulleys, clutch fans and possible idler pulleys will be different from the big NAV. trucks; however, usually have NAV. part numbers on them. I worked at a NAV. dealer for a while--that is how I know. Morale of this story: buy NAVistar diesel engine parts from Navistar--Not Ford and SAVE $$$$$$$$. Sorry FOMOCO--You hose people too much for NAV. engine parts.
