F-250 / Super Duty / Diesel
blinker problem
Old Feb 8, 2004 | 07:20 PM
Whaazup17's Avatar
blinker problem
On my excursion the blinker is blinking twice as fast. It works but blinks twice as fast
I know this isn't a major problem but don't want to let it get into a bigger problem
please is there any fuses or anything I can check??
-garrett
Old Feb 8, 2004 | 08:15 PM
Old Timer's Avatar
Not sure about yours, but have seen this happen. Blinkers are not all the same. I have seen fast ones, but when a TT was plugged it, the blinkers would slow down because of the extra draw from t.signals on trailer.
Maybe normal fast blinking/maybe not? I dont think there's anything else (fuse), just the blinker that plugs in. But, just a guess. Look for updates
Good luck...OT
btw...afterthought, do ck. that X front/rear t.signals are working correctly. As I recall the blinker speed could chg. if lights (bulbs) bad.
Old Feb 8, 2004 | 08:35 PM
Whaazup17's Avatar
thanks a lot
but I did a check and none of the bulbs are out
the left one is the one that is blinking quicker than normal and the right one is normal
anybody else could help
thanks
Old Feb 8, 2004 | 08:57 PM
Rockpick's Avatar
Moderator &
Check your bulbs again.... including your brake lights on that side as well...
My wife's old Contour would go spastic like that when a bulb was blown....
Did it just start all at once?
RP
Old Feb 11, 2004 | 04:29 AM
Mach1's Avatar
Sounds like a ground problem to me, but what would I know???
Old Feb 13, 2004 | 11:31 PM
MKTRUCK's Avatar
25 Year Member
Still could be a bad bulb.
And like the above post said. Check your brake and parking lights. Sometimes the filiments touch.
