F-250 / Super Duty / Diesel
Predator
Old Dec 30, 2003 | 08:00 PM
SVT54's Avatar
Predator
Hi,
I am a Lightning owner and recently bought a predator and love it. I figured I would try and pull some info from you guys here as your a wealth of knowledge. I gave my boss a predator for his 2001 7.3L superduty for xmas. It was 2nd hand and I confirmed the orig owner restored the stock tune so it could be used on another vehicle and it works fine.
My question is we cant seem to find the speedo calibration feature that is advertised for the unit. It is a very late version (Nov17) and its not anywhere in the menu. Also we wanted to change the shift points as under heavy throttle they are way to early but it seems you can only change pressure. Lastly when you command it to display the vin it spits out FFFFFFF's. He was using a REM delta chip and we took it off prior to using the predator.
Thanks for you input...Ron
Old Jan 1, 2004 | 01:39 PM
FamilyRide's Avatar
I'll take a shot (long shot) the speedo calibration is more than likely refered to somehow as rev's per mile for the tires. The lowest that will take is 601 I believe which is as close as you can get for 35" tires if I'm not mistaken.
