V-10 Exhaust
V-10 Exhaust
I have used the search feature a few times and pulled up some info for V-10 exhausts but not much. What exhausts are you other V-10 owners putting on. Everything I have found seems to point to our 10's don't sound to good with aftermarket exhausts. I would like to have a bit more growl to it. So far it's disappointing that the 8's sound better.
Well get used to it, i have heard some real bad sounding v-10's. So i have decided to keep stock. I ran a thread on this about 2 months ago and got hardly any good news of a decent system. Plus you lose some of your low end torque.
Good luck
Good luck
v10 exhaust idea
Mike Troyer was good enough to pass along this post to me so I thought I would pass it along to you.
The Magnaflow cat-back exhaust system is similarly the best exhaust system for these heavy trucks, they're the only company really doing proper flow engineering to prevent loss of torque at low rpms. The power gains on the V-10 from the exhaust system run right at 17-18 HP & 30 lbs./ft. of torque. The Magnaflow exhaust is also made of all aircraft-grade T-304 stainless steel, the bet quality 304 stainless than money can buy, literally. The Magnaflow exhaust system is not a "loud" system, it has a very distinctive & refined growl in the V-10's that is not loud or overbearing, and never "drones" inside the cabin, you'll love the sound as well as the power from it.
You can reach Mike at
Mike Troyer
Performance Products, Inc.
Ford & GM Truck /SUV Performance Specialists
National Distributor for Superchips
National Distributor for Air Force One
Magnacharger National Distributor
JDM Engineering Ford Lightning Performance Parts Distributor
Phone: (540) 862-9515 FAX: (540) 862-9485
Hours of Operation: Monday thru Friday, 10am to 7pm Eastern Time
Superchips Online Ordering System: https://www.f150online.com/scpp/index.html
Mike Troyer
I have a Gibson Swept Side on my F150 w/ the 5.4L. It gives you a good boost of power and torque across the power band with just a very subtle addition of sound. It's also available in stainless steel.
I don't know much about the Magnacraft products, but I highly recommend the Gibson SS.
