Expedition / Navigator
Lowering question
Old Nov 19, 2002 | 12:32 PM
98_EXPEDITION's Avatar
Lowering question
I have a 2wd with LLS (Load leveling suspension) 98 of course, and I have heard something about being able to lower the rear or something by use of bolts underneath the cargo area. Either way, could someone give me some pointers on how to do this, wanna lose a few inches give it a better stance.
Old Nov 19, 2002 | 12:51 PM
SexpeditionSprt's Avatar
Talking
go under the car and you will see a small thing that looks like a shock with a rubber boot on it, this is the load leveling sensor, now what you need to do it unbolt it and somehow move it, wether you need to drill holes in the bracket or whatever, and that thing can bring it down till the tow bar is touching the ground just depends on how low you want it. And always remember, after you do this mod, you need to put the keys in the ignition, and turn it on, you don't need to start the motor, but the key does need to be in the "ON" position, then open and close the driver door, and then watch the thing hit the floor
