Expedition / Navigator
Clanking Noises
Old Oct 3, 2002 | 05:06 AM
expy69's Avatar
Question Clanking Noises
I'm hearing some clanking noises coming from the rear of my truck. It's noticeable when going over bumps and rough roads. Sounds like something is loose. I can't find anything wrong. Anyone have any ideas?
Thanks in advance,
John
Old Oct 3, 2002 | 07:09 AM
VinniePSVT's Avatar
Could be your aftermarket exhaust system.
Old Oct 3, 2002 | 09:22 AM
AlanM96SS's Avatar
Re: Clanking Noises
Thanks in advance,
John
Dont know what to tell you about your rattle, but damn I wished I was in Hawaii!
Old Oct 3, 2002 | 03:31 PM
ScottyBones's Avatar
might be that your shocks are shot, or it could be your swaybar bushings, also check your spare tire.
I had 55000 miles on my 2000 expy when i started to experience a bad rattley ride, i replaced the swaybars front and rear with ones from hotchkis and i replaced the front and rear shocks, now it rides like a lincoln again.
Old Oct 3, 2002 | 04:35 PM
rhdf150's Avatar
I had put new shocks on our Expedition and soon after I was getting a similar noise when going over bumps. To test, I jacked the rear up, took a long pry bar and lifted each tire.(got a clicking when lifting up & down) Sure enough it was the left rear shock- top bolt was a bit loose. I re-tourqed & had no problems since. It was in a tough spot, but I finally did it.
Good luck!
https://www.f150online.com/galleries....cfm?gnum=1142
Old Oct 9, 2002 | 03:22 PM
expy69's Avatar
rhdf150,
How hard is it to get to the shock mount? Did you have to remove stuff?
Old Oct 9, 2002 | 08:34 PM
rhdf150's Avatar
As long as you have the right tools it’s not so bad. I used jack stands to support the frame. Removed spare tire, and left the jack under the differential. (So you can lift up a little to relieve some stress on the shock. Then I got in and tightened the top bolt with a torque wrench. I went crazy before I did my test. I have a Borla catback & 1st thought that was it. (I did end up tightening that up). I read your mods & noticed you have a drop kit. Do you think that has anything to do with the noise? As you see in my previous post the test I did with the long pry bar found the problem. Good luck!
Old Oct 9, 2002 | 11:14 PM
expy69's Avatar
rhdf150,
Thanks for the info.
Could be the drop kit, but the symptoms you describe seem similar to mine. The drop kit was only shocks and springs. I tried the same test as you, although I really couldn't move the tire much. I could create the noise by bouncing on the bumper. I'll check the shock mounts.
ScottyBones,
Checked the spare tire area. Anti-sway bar is secure. I do plan to change to Hotchkis bars too. Thanks
Old Nov 15, 2002 | 06:40 PM
expy69's Avatar
Thumbs up
Found it!
Bad shock bushing. I didn't know you could compress these urethane bushings, but mine was oval shaped and the shock casing was touching the axle.
