Expedition / Navigator
LLS Question
Old Dec 13, 2001 | 12:50 PM
Bigworm's Avatar
Question LLS Question
Hey Everybody - I have heard of people adjusting their LLS sensors to make their Expys ride lower, does anyone know if you can adjust them to make the vehicle ride higher? I want my Expy to sit at its full height all the time. It sits too low for me in AWD. Anyone know how to help?
Old Dec 14, 2001 | 09:30 PM
Dave XP's Avatar
I assume you have the 4 corner LLS. Some have switched the Air suspension Off while 4W Lo is engaged so that the maximum height is retained. The problem with this is it also switches off the Variable Orfice of the Power Steering so you get full boost at highway speeds. Without a complex modification to the electronic box, the only way is to re-adjust the height sensors. I'm not satisfied with only one height so I plan to modify my electronics box to allow any height on demand.
Old Dec 16, 2001 | 03:23 PM
Bigworm's Avatar
Dave - Thanks for the reply - please let me know when you do the modifications, I will be right behind. My problem is that no one here in Arkansas knows what to do.
Any one else got any ideas or suggestions?
Thanks in advance
Old Dec 26, 2001 | 03:25 AM
excelonline's Avatar
Arrow
So how do you adjust the sensor and where is it located?
Ever
Old Dec 26, 2001 | 02:02 PM
Bigworm's Avatar
Excel - I wish I knew - I will keep you updated as I search for THE WAY.
Old Dec 26, 2001 | 03:17 PM
Talking
Ever
Old Dec 26, 2001 | 08:03 PM
FamilyRide's Avatar
The rear sensor is about mid ways just over the rear diff. You can see it pretty easily. Looks like mine could be adjusted about 2" either up or down.
Old Dec 28, 2001 | 02:21 AM
Question
Is there one for the front?
Ever
Old Dec 30, 2001 | 05:38 AM
dbunch5's Avatar
If you have four corner LLS, the sensor is located on the front, top control arm inside the driver's side wheel well. Unfortunately, there does not appear to be a way to adjust it. I have tried to rotate it without much success.
Old Dec 31, 2001 | 01:47 PM
Bigworm's Avatar
Any other Suggestions
Does anyone has an idea on how to modify the system to reach the 4 - Low height on demand? Any help would be great!!
