Expedition / Navigator
High Front End
Old Oct 23, 2001 | 09:13 PM
Boltittome's Avatar
Question High Front End
Just a quick ? on 2000 eddie bauer expy,, The front of the vehicle just plain looks high, If i go under there and back off the torsion bars will it come down an inch or so?? These things look like you could hang a plow on the front! Any feedback would be most appreciated!!
Old Oct 23, 2001 | 10:31 PM
FamilyRide's Avatar
??? I have a 2000 and don't think so. I have rear LLS so the rear adjusts height but the non LLS usually have a bit of a rake, higher from back to front.
Old Oct 24, 2001 | 09:42 AM
Dvds's Avatar
The 2WD look lower in the front, the 4WD is pretty level, at least my 99 EB, as well as others I have seen around here. The 4WD is higher, but level.
Old Oct 24, 2001 | 11:24 AM
Multimedia's Avatar
I have the 2wd with the rear LLS and the rear of my truck sits lower than the front when it's parked. The suspension lowers itself for an easier entry and exit. Once up to a certain speed (can't remember exact speed) the LLS kicks in and levels everthing out.
Old Oct 24, 2001 | 03:13 PM
Boltittome's Avatar
thanks for the replies,,, although i should have stated mine is a 4x4,,,
Old Oct 24, 2001 | 05:34 PM
BoostRetard's Avatar
Mine sits higher in the front too. About 1 inch or so. I'm thinking about raising the rear a couple inches with coils spacers and then adjusting the torsion bars to match.
