Expedition / Navigator
Water goes straight from reservoir to oil pan drain plug and I mean fast
Old Sep 13, 2023 | 05:02 PM
Nathan Pavelsky's Avatar
I have a 2001 ford expedition Eddie Bauer edition 5.4 V8
it sat for a year then was moved and cranked up .. After cranking and ideal for 30 mins started overheating so I **** it off and checked oil ..Not good milky oil and ECT.. so I do what ajy mechanic would do and start with gaskets ..got my intake off replaced and inspected it then replaced intake gaskets put that back and it did the same thing .. new intake was put on with gaskets so I take it back off and try running water through it again same thing with the intake off so I decided time for a compression test of heads and each one came back normal so I'm currently stuck on what to do I've searched and searched nothing I can find and also there is no cracks in the head or the block or cylinder walls please help I'm at a lost
