FamilyRide where's the computer code?
First check on the inside of the passanger front door. There should be a white sticker about 1x2 with 4 alph numeric digits something like ZUT2 on it. It should be near the hinges.
If you can't find it there check the computer itself. On the same side of the truck, where the passangers right foot would be, look up under the dash against the side almost right next to the glove box but up against the side with the end inserted through the firewall. It's an alum. boc about 1.5" x 6" and the long side through the firewall is about 8". It'll have a black plastic "cap" on the back side that you can see that's about the width of the PCM and about 2-3" long. That's the service port where the chip installs. You should see the same sticker on it.
Good luck, I know you'll enjoy the chip!
If you cant locate the computer. Pop your hood and look directly behind your battery, on the firewall you will see a bunch of wires going into the firewall, on a blue or black piece of plastic(connection of all wires) the code is on a sticker here as well.
You also need to remove the bolt in between all of these wires at this location anyway when you remove your computer.
Hope this helps
Hope this helps
HI LILBEAR,
If you have any more trouble, you can always give us a shout too, & we'll **** you thru finding it.
Between Family Ride and BluOvalOK's responses, that should put you in good shape, & thanks to both of them for their help!
