Expedition / Navigator
02 EB Expy trailer running lights not working
Old Jul 19, 2012 | 11:30 PM
dirtslmfan_25's Avatar
I have an 02 that I bought almost 2 years ago. The brake and turn signals work, but no running lights. I've never needed to use my trailer at night till now, so I need some help if anyone has had an issue like this. I've tested the wire almost to the firewall and haven't found a problem. I unplugged the wiring harness under the air intake at the fender and there is no problem from there to the 7 way plug. The brown wire is the one I'm having trouble with. Thanks for any help.
Old Jul 20, 2012 | 06:52 AM
projectSHO89's Avatar
Check fuse F5 and the trailer tow running lamp relay in the under-hood battery box. They might not be installed.
Old Jul 22, 2012 | 11:39 PM
Both fuse and relay are good.
Old Jul 23, 2012 | 06:25 AM
You'll have to test the circuit the old-fashioned way - with a meter and the schematic. You've checked all the easy stuff.
Old Jul 28, 2012 | 02:12 AM
Well, I should have payed closer attention to your post. I checked fuse #5 under the dash, not in the under-hood box. Just found fuse #5 under the hood is bad
