Expedition / Navigator
Need Help
Old Jan 21, 2010 | 04:24 PM
geoelpalillo's Avatar
Unhappy Need Help
Hi, I am having an air suspension problem with my dad's 03 eb expedition. It will fill up fine and all but loses air from one day to the next. My dad has checked for leaks but has not really found any thing substantial. I am afraid we are at a stand still at solving this problem. Any insight you guys may share would be extremely helpful. Thanks in advance....
Old Jan 21, 2010 | 06:52 PM
ELVATO's Avatar
Apply soapy water to all the lines, the compressor, the air springs, and fittings. That should tell you if you have a leak somewhere.
Old Jan 21, 2010 | 07:46 PM
thanks for your input..My dad has found no leaks, Now he is interested in finding the power relay for the system and replacing it. Maybe someone has an electrical schematic?
Old Jan 21, 2010 | 07:50 PM
sampson01's Avatar
either do a spring conversion or track down the problem... had a navi at my work for over 3 weeks trying to find the problem and i ended up putting the spring conversion in ... the resistor for the compressor pump is under the truck behind the passenger fog light... tend to burn out or the connectors get corroded
Old Jan 23, 2010 | 12:13 PM
I just got under it and the relay is not there...where else could it be?I'm sure the connectors are corroded....Previous owner used it on muddy terrain. Thanks once again
