Lowering a 2wd Expy?
Just picked an 05 up for my wife.
What is required when installing a set of lowering springs (like eibachs). Do you need some alignment crap? Or anything else? Just want to do it right the first time
In my experience if your going to be running stock tires you may not need an alignment but if your running anything bigger than stock you might. You may also consider how much your lowering as well as rim size I didnt think of it and now Im rubbing sometimes pertty bad.
how about a 1/1 drop?
my Expy sits level, and I only want 1" less wheel-well gap for when I switch to 33" rubber
its definately going to get done, but I'll probably wait till the chance of snow is over ( late march or early april). The wheels are here sitting in the garage, just need to get the suspension stuff ordered up and throw that stuff in. I shouldn't need shims for pinion angle since the expeditions have IRS. I assumed an alignment was manditory, I just want to make sure I have everything I need before I try to get it done.
I'll be sure to post before and after pics
That won't be necessary since the 03-10 Expy's have independent rear suspension. Adjustable camber bolts may or may not be needed but I can't remember anyone needing them. If you install them, give us a review and post some pics.
23x10 rear
23x9 fronts
looks awesome
I may need to double which ones the tire guy installed were cause they did came off a saleen truck some guy wanted 26's and he was short 2000 for some asantis. All the numbers matched so Im pertty their real oem any way to spot fakes?
