Expedition / Navigator
2000 Expy A4WD ?'s
Old Dec 2, 2009 | 07:32 PM
ougoboy's Avatar
Post 2000 Expy A4WD ?'s
Picked Up a 00 Expedition XLT 5.4 w/A4WD, 4WH, 4WL. Noticed that it drives different from my 98 XLT 5.4 w/2H, A4WD,4WH, 4WL ?? I feel more of a vibration / trembling, in the 00 w/the all wheel drive, It's more noticable when
you step on it hard, and it does not have the pickup that the 98 has w/part time 4WD ? Is this normal for the AWD Expedition / Navigator?
BJW
Old Dec 3, 2009 | 03:07 PM
fiveohpoepoe's Avatar
Check the differential.Under hard acceleration you prob will feel a little something. I took my front drive shaft out because the differential is on the way out
Old Dec 5, 2009 | 10:02 PM
Glen R's Avatar
Check your tires. With the AD system the tires have to be rotated often, or they start wearing funny. My 01 had a pretty good rumble when I got it, ended up it had three different brand of tires(all the same size). Once I switched to new tires, rumbling disappeared. Still get a little vibration on accell if it is slick.
YOu may want to change the diff and trans fluids as well. I did mine a few wees ago and it is smooth as silk now.
