Expedition / Navigator
door ajar and overhead lights stay on, help
Old Feb 11, 2009 | 12:50 PM
sambo8807's Avatar
Unhappy door ajar and overhead lights stay on, help
i have a 1998 navigaqtor and sometimes the lights wont go off, it says the door is ajar but i double check every door and it still stays on. What can I do? Please help!!!
Old Feb 11, 2009 | 01:06 PM
bennysboomboom's Avatar
see sticky below
Old Feb 11, 2009 | 08:23 PM
wwwabbit's Avatar
You can find out what door is causing it by opening all the doors one at a time, any new doors will ding at you, if you open a door and it does not ding, that would be the one sticking.
Old Feb 12, 2009 | 09:44 AM
Camarothatcould's Avatar
You need to go through every door and spray a heavy amount of Penetrating oil, such as WD-40 or PB BLaster into the locking mechanism. One of your switches for door ajar is sticking open. Once you spray the latches and open and close them a few times, it'll be fixed. I havnt had it happen in years cause I soaked the crap out of the latches
Old Mar 11, 2009 | 02:40 PM
Dem beats's Avatar
This happens in the winter the most I bet too. For me it's when it changes from cold to hot hot to cold outside quickly.
The wd-40 will work probably. I don't think I soaked mine enough. Mine will something come on in the middle of a drive for no reason. Just snaps on while cruising down the highway.
