Expedition / Navigator
08 speaker help
Old Jan 9, 2009 | 05:18 PM
thenewbreed's Avatar
08 speaker help
I want to add speakers to the third row for travelling. I know there is a lot of room in the plastic molding on the side. I was thinking about cutting holes and attaching them so you only see the top of the speaker.
Has anyone does this.
Also I would like to see what you guys have done with sub installs and still not loose any space.
Old Jan 13, 2009 | 04:11 PM
Buzzz's Avatar
I have wanted to do this too. You may have to add an amp, as wiring it with the head unit might pull too much current through it. I would install some 5x7's and use the grills.
Old Jan 14, 2009 | 01:27 AM
I think Ill pick up a small amp. I don't I need much power to run those speakers plus the factory. I have two audibahn amps but those are going in the Screw.
I will start looking into some 5x7's
Old Jan 14, 2009 | 11:44 AM
Buzzz's Avatar
Just make sure that the location of the speaker won't impede the third row seats from going up or down.
