Expedition / Navigator
02 rear bags jacked
Old Nov 26, 2008 | 07:21 PM
silver_FX4's Avatar
02 rear bags jacked
its a 02 4wd and the rear air bags arent leaking, but there filled to the top. the front is in its normal height. and the rear looks like its 2 times higher than it should be. Nothing underenath is broken or bent. Anyone had this before??
Old Nov 28, 2008 | 12:58 PM
2000Expedition's Avatar
Could be a bad sensor, ...try turning the unit off. (the switch is underneath the glove compartment on top of the right side kick guard)
Turn it off and drive around for a while. it should slowly release
If you turn it back on and it goes back up ... its a sensor and a good problem as opposed to you having no air in them and something expensive to fix
