Expedition / Navigator
01 Trailer plug issues
Old Jan 2, 2007 | 03:16 AM
idbl_fanatic's Avatar
SO I went to rent a trailer today, and when we went to check the lights, only the left turn/stop/hazard will work, ONLY the left side!! I don't understand this, are there seperate fuses maybe for each function? I have used this before towing and everything worked fine.
Old Jan 2, 2007 | 03:12 PM
G.Andrews's Avatar
i had a similar problem a while back...
just had to use an electronics spray cleaner to blow out the contacts in that connector, because the dust cap doesnt seat too well on mine.
blew out all the gunk and it works like a dream!
Old Jan 2, 2007 | 03:15 PM
newmandl's Avatar
Also, there is a fuse for the right side and left side, if I am not mistaken.
Old Jan 2, 2007 | 11:29 PM
Where is it located at?
Old Jan 3, 2007 | 01:14 AM
Zaairman's Avatar
Under the hood. All trailer functions have a separate fuse.
Old Jan 3, 2007 | 11:24 AM
jorlee's Avatar
Page 186 In Owners Manual shows Under Hood Distribution Box Diagram.
Check fuse 5 park lamps, 19 right turn/stop,
Old Jan 3, 2007 | 04:20 PM
Thanks all, I think I found them!!well at least one fuse blown for the right stop/turn I will have to check the rest of the fuses for the park lamps
Old Jan 6, 2007 | 09:48 PM
Thanks everyone, this was it, Fuse 5 and 19 were blown, I had towed a trailer before, and the lights worked, then all of the sudden stopped, so I am *** U ME ing that there was a short in that trailer, that's the last time I Saw them working, I just replaced the fuses today, and went and rented a trailer and it worked fine.
THANKS AGAIN!!
