Expedition / Navigator
!997 Ford Expedition error code p1450
Old Nov 19, 2005 | 03:41 PM
Albornoz's Avatar
I have an error code p1450,,Does anyone know what that code is???
Old Nov 19, 2005 | 09:45 PM
01SILVERGT's Avatar
P1450 Unable To Bleed Up Fuel Tank Vacuum
-Evap canister purge outlet tube (EVAP canister purge valve to EVAP canister) blockages or kinks.
-EVAP canister tube (fuel tank to EVAP canister) blockage or kink
-Fuel vapor elbow on EVAP canister contaminated
-Restricted EVAP canister
-Canister Vent (CV) solenoid stuck closed (patrially or fully)
-Plugged or conaminated CV solenoid filter
-EVAP canister purge valve stuck open
-Fuel filter cap stuck closed (no vacuum releif)
-VREF circuit open in fuel tank pressure (FTP) sensor
-Damaged FTP sensor
-Check for kinks or bends in the fuel vapor hoses / tubes.
-Visually inspect EVAP canister ports, CV solenoid filter and canister vent hose assembly for contamination or debris.
-Check CV solenoid filter for blockage or contamination
-Check fuel cap (I would start here, its easy and cheap)
