Expedition / Navigator
Expedition shock install
Old Feb 22, 2005 | 04:50 PM
01SILVERGT's Avatar
Not sure if anyone cares, but I changed the shocks on my friends Expedition over the weekend. I read many threads that gave only partial information on how to do this, so I thought I would provide a full front and rear write up for those that care.
First off this is a 2000 Expedition E.B., withOUT LLS. I installed Bilstein Shocks on all 4 corners. Bilstein part numbers were as follows:
Front – BE5-2571
Rear – BE5-2573 (NON LLS)
Tools Needed:
Small flat blade screwdriver
21mm wrench
20mm wrench
18mm wrench (2 needed)
¾” wrench
6mm allen wrench
13mm wrench
Optional tools:
21mm socket wrench
18mm socket wrench
13mm socket wrench
SAFETY FIRST. Think safety all the time and work accordingly. Use gloves, and glasses at all times to protect yourself. Use wheel blocks to prevent the vehicle from rolling and use jack stands to rest the vehicle on. DO NOT rest the vehicle on the jack and get under it.
FRONT:
First jack the front of the truck up, and place jack stands under the frame rails. The higher you can go the easier shock removal and install will be. Also be sure to block the rear tires to prevent the truck from rolling back. Now I removed the front tires, to make access to the shocks easier, but you can also do the job without removing them, although it is much harder. After removing the front tires, spray the top nut and bottom two nuts of each shock with WD40. Give this some time to soak in. During this time I started to put the new shocks together, by this I had to thread the new rubber bushings provided onto the new shocks. Once I felt enough times had passed I went to work on removing the front shocks. I first used a small flat blade screwdriver undo the clip holding the ABS sensor line. I then tucked this line out of the way and unscrewed the clip from the top of the shock. Next I used a 13mm wrench (or a socket wrench) to loosen (do not remove yet) the bottom 2 bolts from the shock. Next I took my 21mm wrench and turned the shock so that I could get the 20mm wrench on the bottom nut on the shaft. Once the 20mm wrench was in place I was able to remove the top nut with the 21mm wrench. (Note: on the passenger side you can use a deep 21mm socket. On the drivers side you can not use a socket due to a bracket that sits just above the shock tower.) After I removed the top nuts, I then proceeded to finish removing the bottom nuts with the 13mm wrench. At this point the shocks should just slide out, you may have to angle them a bit to get them out. If you’re not high enough in the air you may need to compress them to slide them out.
Now comes the fun part of installing the new shocks. My truck was high enough to just angle the new shocks back in, but you may have to compress yours if you are not up far enough. Once I had the shock in the tower, I reused the 13mm bolts on the bottom and just put these in hand tight. Next I used a jack, placed under the shock to lift it up into the shock tower till the rubber bushing was pressing against the bottom of the shock tower. (I raised the jack till it started to lift the front end a bit) Next I installed the top rubber bushing and associated hardware provided with the shock. Be sure to use the nut provided with the shock on the Bilstein’s, as the old nut will NOT work. To tighten the new nut you will have to use a ¾” open end wrench, and hold the top with the 6mm allen to prevent the shaft from spinning. I tightened to the good old German method of good-en-tight. As you tighten the new shocks in place you will notice the pressure will start to relieve on the jack as the bushings compress and the A-arms rise back in place. After I tightened the top nut, I removed the jack and tightened the bottom two 13mm bolts to manufactures specifications (good-en-tight). I then screwed the ABS line bracket back on the shaft and put the line back in place and clipped it back in. Before you put the tires back on, make sure all nuts and bolts are tight and to the proper specs, also make sure the ABS lines are positioned so that there are no kinks and that they will not kink when you turn the wheel. Re-mount your wheels and drop the front end.
Old Feb 22, 2005 | 04:54 PM
01SILVERGT's Avatar
REAR:
First block the front tires and jack the rear up as high as you need to get under the vehicle. (For me this is high, as I am fat) Place your jack stands under the rear axle on each side, and slowly let the truck rest on these. I also kept one jack in place to provide a triple redundant safety from collapse. Next remove the rear wheels (this really is not a necessary step, but for me it was easier than trying to work under them). I then sprayed the top and bottom bolts with WD40, and gave them some time to allow it to work in. Now begin by using the two 18mm wrenches (or socket wrenches) to remove the bottom bolt from the rear shocks. Next you will need to remove the top bolt. On the driver side this was a real PITA, due to the fact that you could only access this with a 18mm open-end wrench, and turn it just a ¼ turn at a time. Thank god Ford decided to put a captive nut on it, so you only have to remove the bolt. On the passenger side the set up is the same, but you can use a 18mm socket wrench to remove the top bolt. After the bolts are removed the old shocks should just pull out. Install the news shocks in the reverse order. Some notes on installing the new shocks: I have to use a Dremel to grind off some of the top rubber bushing to get it to fit with the captive nut in place. You may or may not have to use a jack to compress the shocks to fit them in the bottom bracket. I was able to compress each by hand (very hard) and let them expand into place.
Hope this helps and hope some of you get good use out of this. I was able to ride and drive in this truck before and after the shock install and all I can say is WOW, these Bilstein's are really something else. I will be installing them on my 99 Expy with LLS, so stay tuned for a write up on this in the near future.
Old Feb 22, 2005 | 08:34 PM
Jordan not Mike's Avatar
Thanks for the write-up.
I was able to change the rear shocks on my 97 Expy (with LLS) in about 30 minutes, without jacking up the rear or removing the tires, FYI.
The driver's side took the most time, for the reasons you noted.
The fronts looked like a PITA, so I paid a shop to do those
Old Feb 22, 2005 | 08:53 PM
01SILVERGT's Avatar
The fronts were much easier than the rear, I thought. I found I had to lift the rear to get under the truck due to my thick chest.
Old Feb 23, 2005 | 02:13 PM
Methinks I should have attempted to do the fronts, then.
It just looked so cramped for space that I didn't even attempt it.
Old Feb 24, 2005 | 04:26 PM
01GreenCrew's Avatar
How does the Expi ride with the Bilsteins? I've had them on 2 vehicles in the past, 1 was a 98 Dodge Ram Quad Cab and the other was an 87 Buick Grand National. They were excellent shocks on both of these vehicles.
Old Feb 24, 2005 | 07:19 PM
I only have them in the rear... long story. I've got adjustable Ranchos in front.
I think they provide a good, controlled ride. A little firm at first, they got a little softer (or I just got used to them) after a few thousand miles.
Old Mar 24, 2005 | 01:57 PM
dayalalito's Avatar
SLIVERGT,
SUPER DIY PROJECT IM CHANGING MY SHOCKS
THANKS FOR THE INSTALL TIPS !!!
Old Mar 27, 2005 | 04:35 PM
patf's Avatar
good timing for me as well. i received my bilstiens for the front, but the rear are backordered till mid april..
Old Mar 28, 2005 | 12:40 PM
01SILVERGT's Avatar
Let me know if any of the bolts or nuts are a diffrent size on your 99. I am waiting to order shocks for my truck, and I also have a 99. The sizes above are for a 2000, so I am not sure if they are different from year to year.
Old Apr 18, 2005 | 04:56 PM
dayalalito's Avatar
Found BILSTIEN SHOCKS
I FOUND THEM ON EBAY FOR 100.00 ALL FOUR , THE GUY SENT ME THE MODEL NUMBERS, I CALLED BILSTIEN COMPANY AND THEY VERIFIED THOSE WHERE THE ONES FOR MY TRUCK......
Old May 16, 2005 | 11:17 AM
dayalalito's Avatar
Cool New Rear Shocks Installed !!!!!!
I Finally installed the BILSTIEN SHOCKS , WOW what a difference these things
are TIGHT, did only the rear and trust me you can feel the diffrence, will will be instaling the front within the next two weeks, i have to order replacement dirt boot for one of the shock, so i dont want to install only one so io will wait for it to come in.
These shocks are so tight that the truck doesnt rock at all, and very easy to install didnt even have to raise/jack up the truck.
Old May 16, 2005 | 11:18 AM
dayalalito's Avatar
are TIGHT, did only the rear and trust me you can feel the diffrence, will be instaling the front within the next two weeks, i have to order replacement dirt boot for one of the shock, so i dont want to install only one so i will wait for it to come in.
Old May 17, 2005 | 11:50 AM
Scot008's Avatar
I just replaced the 70,000 mile OE shocks with Bilsteins on my 2001 EB 4WD without LLS, and the difference is noticeable. The ride is more controlled. Although some sharp, small to medium bumps seem more pronounced, the ride is much more pleasant becase the suspension does not oscillate after each bump. These bumps may seem more obvious only because there is so much less "noise" of the suspension overreacting to the road, and other less sharp and larger bumps are clearly less pronounced. Body roll and wallowing is reduced, but I feel I could use two more of these shocks in the rear to get total control of wallowing. Overall, the ride is better and less fatiguing. I would recommend these shocks to anyone with a similar vehicle. Next, I will be replacing the heavy steel wheels with aluminum to decrease unsprung weight (by 8 lbs per wheel). Along with the wheels will come OE size (265/70/17)Michelin Crossterrain tires (for comfort and durability). After that, I will replace the OE rear sway bar with a Helwig, which should further control the wallowing.
Old Sep 17, 2006 | 10:39 PM
brandonj's Avatar
I just found on my 2001 Expedition that the driver side rear, upper bolt is much more easily managed with a really long extension and socket wrench. With a long extension that will bring you out to about the rear end, you can stick your whole arm and wrench right up beside the rear end and the task is no problem after that.
