Expedition / Navigator
strange electrical problems
Old Feb 14, 2005 | 10:25 AM
ranwin's Avatar
I own a 2001 Ford Expedition. Recently the heater fan would continue to run after I turned the vehicle off - the only way to stop it was to turn the heater control to off. This happened with both back and front heaters. I also noticed when I turned the vehicle off, removed the key, and opened the door the chime would continue as though I had left the lights on. Additionally my remote keypad for the door locks only works intermittently, I have replaced it's battery and reprogrammed it. This has stopped for now, but now the radio and windshield wiperes will not work when I change the transmission from park to drive. Any ideas what might be causing the problems? Thank you.
Old Sep 1, 2008 | 05:58 PM
jason8225's Avatar
I've had this exact same problem.
Only happens after rain (or other moisture causing outdoor event).
I think the fix is here:
http://www.ford-forums.com/ford-expe...l-problem.html
