Do I need to tighten sway bar links?
It seems the front end is floating a little bit after hitting some bumps, even on regular pavement on a 2003 Expedition 2 wheel drive.
I've checked for loose bolts and found some on the rear sway bar links. Tightened them down fine.
The front sway bar links have a little gap at the bottom of the link just before touching the suspension and the rubber boot that protects the bottom of the link itself. Does this need tightening too?
I've tried to tighten them down but they seem tight, unless I'm supposed to lift the truck off the floor to tighten them down.
