Expedition / Navigator
tire rub sound?
Old Jun 11, 2004 | 04:34 PM
lightninquick's Avatar
tire rub sound?
i have a 2004 eddie bauer expy with a 5.4
the vehicle is great except for one thing
when the vehicle is cold the tires sound like they rub when i turn.
no sign of rubing at all and when it warms up it goes away somewhat
they are original tires and wheels
Old Jun 11, 2004 | 08:39 PM
ScrewedFord's Avatar
Sounds like my problem.
I have a 20004 Expy 4wd with limited slip differential.
Sounds like its coming from the front, but its the limited slip rear diff clutches chattering. Goes away after a couple of miles, right???
They changed the fluid and added friction modifier, helped some but not all. I have an appointment next week to replace the clutches.
Old Jun 13, 2004 | 09:17 PM
Fordllllllllll's Avatar
Had the same problem with my 2004.The dealer replaced my clutch packs and it went away.
Old Jun 15, 2004 | 05:02 PM
thanks guys i
Old Mar 10, 2005 | 07:27 PM
hilsonp's Avatar
I am having similar problems. Last week I had the differential fluid changed and since then I have noticed the rub. Sometimes its pretty bad other times not at all. I am afraid to go to the dealer. They will most likely charge me an arm and leg. Any suggestions?
Old Mar 11, 2005 | 04:03 PM
bwmcintosh's Avatar
Hey guys. Sounds like what I was trying to describe in my post "03 Expy / roaring when turning and mild exceleration. " I'll ask that question also when I take it to the dealer.
Thanks!
Old Jun 2, 2005 | 05:02 PM
bwmcintosh's Avatar
Mine is at the dealer as we speak. They said that they were replacing the clucthes in the rear end. I'll let you know how it comes out.....
Old Jun 8, 2005 | 01:19 PM
bwmcintosh's Avatar
Fixed under warranty. No sounds nor tires gripping hard. I hope they don't go out after another 30k....
Old Jun 8, 2005 | 01:32 PM
Jordan not Mike's Avatar
If it is indeed coming from the rear differential area...
If you are out of warranty you can try changing the rear differential fluid, making sure to to add the limited-slip additive, which is designed to eliminate chatter. Or use a limited-slip-specific fluid, which will already have the additive.
Or you can also try just adding some of this additive without changing your fluid.
A bottle is only like $5 at the dealer.
