Expedition / Navigator
2004 Expedition With 4R75 Trans
Old Dec 11, 2003 | 03:44 PM
svtbrad's Avatar
Question 2004 Expedition With 4R75 Trans
I just purchased a new 2004 Expedition Eddie Bauer which is equipped with the AODEW / 4R75 transmission. Before I took delivery I had the dealer put it up on a hoist so I can check the undercarriage for damage. During my inspection I noticed that the transmission pan does not have a drain plug.
I went looking for an upgraded pan with a plug on the net and found nothing on the 4R75 trans.
During my search I came across some info that this is the same trans in the new 2004 F-150.
Is the 4R75 a new trans from Ford and will a 4R70 pan fit?
Thanks for the help.....
Old Dec 11, 2003 | 10:04 PM
PaulC's Avatar
To answer one of your questions, 2004 is the first model year for the 4R75.
Old Dec 12, 2003 | 10:00 AM
fx4x42002's Avatar
The 4r70 doesn't have a drain plug either. But there is a spot for an aftermarket plug. The first time you have it off, drill a hole and put in your own plug. Of course if you don't do your own service, then let the mechanics worry about it. :>)
Old Dec 18, 2003 | 08:37 PM
horkn's Avatar
all these trannys are still using the aod based trannys, so i am sure you could find one that works. but i would look at it first before assuming this.
