Expedition / Navigator
What differentials do i have?
Old Oct 8, 2003 | 01:52 AM
rub's Avatar
rub
Want to change all fluids but need to know what transmission i have an what differentials my expy have VIN is 1FMFU18LXVLA25704 my axle code is H6
Engine 5.4 4x4
thanks all for your time
Old Oct 8, 2003 | 11:00 AM
4Xpy4's Avatar
Easiest way to determine diff is to look at the metal tag on the rear diff. It will have a 975 for 9.75in rear and either a 331 or 373 depending on if you have the 3.31 or the 3.73 gear.
Old Oct 8, 2003 | 12:08 PM
PaulC's Avatar
Here's a little primer on Expy axle codes:
17 = 3.31 non-limited slip
19 = 3.55 non-limited slip
H6 = 3.73 limited slip
H7 = 3.31 limited slip
H9 = 3.55 limited slip
Make sure that you use the appropriate additive for limited slip differentials.
As a 1997 5.4 4x4 Expedition, your transmission should be an E40D. Take a look at the "TR" section on the sticker on the driver's door. If the letter "E" is printed below "TR", I'm right.
