'01 EXPY Rear Ent. Sys.
Is there an easy way to swap the vcr in the console to a DVD player. Is it as simple as just swapping the unit? I haven't really gotten into it. I was just wondering if anyone had done it? If so, what unit did you use? Thanks,
EH
EH
Try www.crutchfields.com. If they have direct OEM replacment/upgrade pieces they'll show have it.
The problem you will run into is the fact that the DVD player will be vertical... I actually went to the Crutchfield store in Harrisonburg Va and asked about it.... essentially if you could find a DVD player that has a tray like the old PCs (where the CD would snap onto a spindle) it would work.... I've considered putting one under the rear seat and running the cables hidden all the way through the headliner and pop out just at the display unit....
